HP DJ800, second opinion
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    The plotter shows a diagram of the plotter on the screen with a flashing X over the right hand side. I have never seen that before, nor had the guy I used for tech support. I couldn't find it in the manual. I pulled the nic and the formatter. The hdd was hot. Had probably been sitting like that for a day. I ordered a new formatter with the disc and a new dimm. Should this fix the issue or could there be another issue?
  • Lance15
    • Jun 2015
    • 1088
    Re: HP DJ800, second opinion
    Have seen that icon when performing the emergency firmware loading procedure (think that was it.....been a while). The HDD/formatter should take care of the problem. Good call on ordering the DIMM too. It may have gotten fried if the HDD was that hot.
    • Kiran Otter
      • Dec 2013
      • 1115
      I had this for the first time a couple months ago, and it was a failed electronics module.
      Kiran
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Kiran
        Thanks for the reply. Still waiting for parts. Will update.
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          I forgot to update. Repair just happened last week. The electronic module fixed the issue. Once it started to boot, got 63.03 code which was confusing because it wasn't networked. Found the error was in the tn620. After getting it to boot, I reinstalled the old formatter and verified that it was also bad. Working great.
