Designjet T1120 Phantom 86:01
  • Lance15
    • Jun 2015
    • 1088
    Have a T1120 that is getting a "phantom" 86:01 jam error. Was told it happened after loading a new roll.
    Found once onsite:
    The blue hub on the roll was backwards
    Printhead cover wasn't locked
    Fixed both of those, error continues.
    Tried further:
    Cleaned the encoder strip
    Checked to make sure the cutter was installed correctly
    Ran starwheel diag - PASSED
    Ran service station diag - PASSED
    All good. Am able to smoothly move paper back and forth through the paper path with no resistance. Checked both ends and under the carriage for any debris.
    How plotter acts upon bootup:
    Disk check
    Carriage give a quick stutter
    Carriage goes to left end, then, back to service station
    Starwheel assembly actuates
    Plotter throws 86:01 after maybe 1-3 second delay
    Any ideas?
    Thanks!
  • Lance15
    • Jun 2015
    • 1088
    Re: Designjet T1120 Phantom 86:01
    Hmmmmmmm. Just checked CSN. Found "HP Designjet T Printer series - Carriage Touching in the Right Front Trim". It talks about checking the carriage rear bushing. Oiling, if necessary and the Pen to Paper Space (PPS) solenoid. The PPS solenoid is on the same side as the service station which is where it seems to halt.
    I'll have another look and report back.
    • theengel
      • Nov 2011
      • 1784
      I think the last time I had one like that I ended up replacing the carriage.
      • Kiran Otter
        • Dec 2013
        • 1109
        It throws the error when it's over the service station? Was the service station replaced? It may be installed incorrectly. You can lower it down but keep it connected, and see if it boots, then you know it's some interference with the service station.
        I'd also check the encoder strip very closely.. take it out and hold it up to the light, make sure the marks aren't damaged or missing in that area.
        Try booting it with all the supplies removed, too.
        Kiran
        • Lance15
          • Jun 2015
          • 1088
          Thanks Kiran. Nope, I've been the only one who's performed service on this plotter. The only other work I did was replacing the belt last September.
          I ran additional tests. I ran the carriage test, and the PRS test. I removed the right hand cover when I ran the PRS test to watch the part move. Both of these tests passed. While I had it off, I cleaned the encoder strip again really good with just a water dampened towel. I put a flashlight up to it and examined it closely. It looked okay. I also closely checked again for any paper debris. Still couldn't find anything.
          engel - the carriage PCA?
          I'm stumped on this one.
          • theengel
            • Nov 2011
            • 1784
            I had a Z3200 that kept stopping with this code over the service station... after the customer had tried to replace the belt. I fixed the belt placement, and then tried replacing the encoder strip. I made sure everything looked right on the carriage. Finally, I figured I'd start with the carriage PCA. But the customer was already in a fighting mood because I hadn't fixed it yet, and I didn't feel like dealing with any 'maybe's. Actually, I was still just guessing. Anyway, I went with the entire carriage unit, and that ended up fixing it.
            • theengel
              • Nov 2011
              • 1784
              Yeah, here's the thread:
              http://www.copytechnet.com/forums/hp...ighlight=z3200
              • Kiran Otter
                • Dec 2013
                • 1109
                Is the rear carriage bushing where it belongs? It's the same as on the 500/800s.
                Kiran
                • Lance15
                  • Jun 2015
                  • 1088
                  Kiran - Yeah. I checked that rear bushing. It's working as it should be.
                  • Lance15
                    • Jun 2015
                    • 1088
                    Wow! Whole carriage assembly for $101 (HP)!? Am I or it missing something?
                    • Kiran Otter
                      • Dec 2013
                      • 1109
                      Sounds used. And I would just replace the carriage PCA. If it's a bad encoder, that would take care of it.
                      Did you try dropping the service station a bit as a test? I know it's unlikely but I would rule out the service station causing some interference.
                      Kiran
                      • Lance15
                        • Jun 2015
                        • 1088
                        That is our price from HP. 15%? discount for being a partner. We have to purchase so much from HP to maintain our status.
                        No, I didn't drop the station. Everything passed the diags. The station homed, capped, uncapped, etc all while the carriage was sitting on top of it. I would have thought that if something was rubbing or in the way, the diag would have halted and failed.
                        I'll order the PCA and report back. It's been difficult getting to this customer as they are a non-contract customer. Have had several plotters on my plate lately and I'm the only tech who can work on them.
                        Thanks everyone for suggestions on this head scratcher.
                        • Kiran Otter
                          • Dec 2013
                          • 1109
                          What part number was it? I'm just curious if it's the carriage alone, without the PCA or flex cables, etc. That price just doesn't sound right.
                          Good luck!
                          Kiran
                          • Lance15
                            • Jun 2015
                            • 1088
                            I've conceded.
                            Kiran - Carriage part number is CK837-67027. Manual says it includes everything. MSRP is $155.87. We get a $54.55 discount.
                            I replaced the carriage PCA. Same error! The ONLY thing I didn't do, mainly due to having to balance cost, is remove the carriage and inspect it. I took a can of air to it. Underneath. Where the encoder strip goes through. Same error.
                            What I did:
                            Re-cleaned the encoder strip and inspected
                            Ran the Starwheel diag - PASSED
                            Ran the Service Station diag - PASSED
                            Ran the Carriage diag - PASSED
                            Ran the APS or PPS (whichever you call it) - PASSED
                            Removed all covers, including the cleanout to check for obstructions - NONE
                            Paper moves smoothly through the paper path, even underneath the carriage. SOMETHING had to happen that I'm not being told when I found the blue roll hub on backwards and the printhead cover unlocked.
                            Another agency says they can have the plotter they don't use.
                            Thanks again for all the suggestions and help on this one.
                            • Kiran Otter
                              • Dec 2013
                              • 1109
                              Hmm, I would have put money on the carriage PCA being the problem.
                              Also on the price, I remember when they changed the trailing cable on the Z series, you had to buy the carriage and cable together and it was over a thousand dollars. I'm realizing that isn't the case here.
                              I'd go down the path of replacing the encoder strip, trailing cable, then the main PCA. Something is making it think the carriage is stuck. I understand if it's become a lost cause though. I hate these kinds of problems!
                              Kiran
