HP Officejet Pro x451dn
  • kirkeb
    • Dec 2012
    • 31
    [CQ] HP Officejet Pro x451dn
    Customer has one of these. Won't print in center of page. Prints on right and left margins ok. Center is blank. Cleaning printhead will let it work for short time then it goes back to not printing in center. Any ideas?
  • Lance15
    • Jun 2015
    • 1086
    Re: HP Officejet Pro x451dn
    Are genuine HP inks being used? Had a customer with a similar issue on this model. It would cut off one of the sides of print. I knew they were using 3rd party inks. After some troubleshooting, it looked like that side of the printbar was just damaged by the 3rd party inks. Clogged it up. No amount of cleaning would unclog the jets. Way to costly to replace the printbar.
    • kirkeb
      • Dec 2012
      • 31
      Customer is using genuine HP ink
      • Lance15
        • Jun 2015
        • 1086
        Does it show any error messages? There is a service note pertaining to the printbar.
        OfficeJet Pro X series (X451dn, X451dw, X551dw, X475dn, X476dw, X576dw Printbar Failure for Flex.pdf
        • Iowatech
          Not a service manager
          • 3930
          Would it be possible for you to show us an example of that print defect?
          I'm kind if thinking that is either bad paper or a problem on the print platen, but I would prefer to see what's going on and use that to determine what actually needs to be done next rather than just tell you wrong things like a moron.
