HP 4250 LCT Jams 13.01.00
  • JR2ALTA
    • Feb 2010
    • 2033
    I don't see many of these tray 3 large capacity cassettes, but they look pretty simple.
    I am getting nearly constant 13.01.00 jams where the paper doesn't leave the cassette. There appears to be a rub mark on the paper as if it's stopping at the sep roller.
    So far I have replaced the pulleys and swapped the sep torque limiter with tray 2. The feed solenoid does work and doesn't stick. The LCT drive is powered by the tray 2 drive pack and all that is turning properly. Tray 2 works fine
    Any help would be great on what to order if you've seen this problem.
    Thanks in advance
  • Lance15
    • Jun 2015
    • 1087
    Re: HP 4250 LCT Jams 13.01.00
    Feed/Seperation rollers (RM1-0037) and pickup roller (RM1-0036) would be the first to replace. You should also take apart the tray and re-pad the pickup solenoid. These things get sticky over time. Very common.
    • jper34
      • Sep 2011
      • 225
      Ive had solinoid troubles too..or replace the whole feed assem., its not too expensive or hard to replace..good luck
      • Wild Bill
        • Jul 2005
        • 774
        Thanks in advance
        The mark would be RM1-0036 spinning on the paper with-out pulling it in.
        1. Replace All x3 Rollers,
        2.look at pressure of pu arm.
        3. replace or scrap it. They are very cheap online.
        Izzy
