9040mfp check cables?
  • mrfuser
    • 1611
    Got a strange problem. Clients 9040mfp won't initialize scanner. Says check cables and we have replaced
    scanner control board, scanner power supply and scanner motor. Same result. The scanner does not move at all. We can easily slide it back and forth manually but no good on its own.
    Any ideas?
  • Lance15
    • Jun 2015
    • 1086
    Re: 9040mfp check cables?
    Had the same issue on a Color LaserJet 4730. Turned out to be a formatter issue.
    • 20 year tech
      • May 2014
      • 577
      old tech pub from the archive
