This customer has a transfer belt assy failing with 97,000 copies on machine. Seems that is pretty early. Is this how long they last or did something cause this to happen. They said they used one Reman toner drum unit once but haven't since. The problem is lines on copies like tsfr cleaning blade failure... Thanks so much for any comments
HP LJ Enterprise 700 M775dn Transfer belt failure...
Re: HP LJ Enterprise 700 M775dn Transfer belt failure...
You'll get a life message at 150K, but I've never had one fail early. I've installed 1/2 dozen of these kits.
Primary transfer cleaning problems could conceivably be caused by aftermarket toner, but that certainly should have depleted itself. If you think there's any chance of the aftermarket toner remaining in the system, I would replace the primary belt, black imaging unit and black toner as a set. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Primary transfer cleaning problems could conceivably be caused by aftermarket toner, but that certainly should have depleted itself. If you think there's any chance of the aftermarket toner remaining in the system, I would replace the primary belt, black imaging unit and black toner as a set. =^..^=Comment
