Designjet Z6100 86.01
  • theengel
    • Nov 2011
    • 1784
    This call started with 'blurry' prints. You can see the scan axis edges of the image below. I figured I was looking at an encoder strip problem, so I replaced that. Halfway through the printhead alignment, I heard a clunk and got a 86.01 error. I can easily move the carriage back and forth. Now, as soon as I turn it on, I hear a slight bump from the axis motor, and it immediately gives me a 86.01. I'm figuring it's the motor, but I wonder if it's a board. If you look hard enough, you can see some banding in the diagnostic print as well as the blur on the edges.
  • Kiran Otter
    • Dec 2013
    • 1116
    Re: Designjet Z6100 86.01
    I'd replace the encoder sensor in the carriage before replacing the motor. In all my years, I think I've only ever had to replace one carriage motor.
    Does it do the same thing if you move the carriage to a different position?
    If you replaced the encoder with the encoder strip, then I'd suspect the carriage PCA. I'd perform the scan axis test, and the carriage assembly test.
    Kiran
    • theengel
      • Nov 2011
      • 1784
      Yeah, it does the same thing in every position. There's a bump, but the carriage doesn't really move, and 86:01
      • Kiran Otter
        • Dec 2013
        • 1116
        Did you replace the encoder sensor? I seem to remember the strip coming with the encoder.
        Kiran
        • theengel
          • Nov 2011
          • 1784
          The one that I replaced didn't have the sensor with it. So no... just the strip. I would have thought that the motor would move a few inches before throwing up a code, even if the sensor is bad.
