HP 4345 MPF
  • R2D2
    • Jul 2017
    • 2
    [Misc] HP 4345 MPF
    Machine in not able to fax out or receive...The Fax Icon in not visible.
    Is this a formatter issue. If so does the formatter board include the fax boart..
    Printing is working o.k. Just not able to fax..has anyone seen this problem.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: HP 4345 MPF
    First try cheaper things like cold reset or reload firmware.
    This model have Analog Fax Accessory:
    Q3701A
    LJ 4345/x/xm/xs mfp,
    LJ M4345/x/xm/xs mfp
    • R2D2
      • Jul 2017
      • 2
      Re: HP 4345 MPF
      thanks alot for the Fax board part# Zoraldinho..I'm gonna do a cold reset for sure..as far as the firmware goes...How is is this done..
      Is thru laoptop and crossover cable..Can you let me know what steps to take..Thanks a bunch...
      • Lance15
        • Jun 2015
        • 1089
        Re: HP 4345 MPF
        As long as it's got a static IP, use a laptop and crossover cable using FTP. Much faster.
