HP PAGEWIDE PRO MFP 772dn FREEZING
  • wilbert.c
    • Apr 2014
    • 24
    [Misc] HP PAGEWIDE PRO MFP 772dn FREEZING
    I installed a new HP PAGEWIDE PRO MFP 772dn FREEZING about 3 weeks ago. The machine is keeping on showing message network cable disconnected though the cable is properly inserted and eventually the machine just freeze. I usually reboot it and it starts working fine after rebooting it. Tried different cable, set it not to go to sleep mode and set link status to auto instead of 100MB but still, the problem is keeping on coming. Any idea I can't keep on switching off and on my machine.
  • Kiran Otter
    • Dec 2013
    • 1116
    Re: HP PAGEWIDE PRO MFP 772dn FREEZING
    Just a shot in the dark, but try disabling IPV6 in the settings, if it's even an option.
    If it's a new printer, why not contact HP about it? It should be under warranty.
    Kiran
    • austonrush
      Sharp & HP Tech
      • 242
      Did you update the firmware? Is the printer setup on a static IP? Have you tried plugging it into a different port on your switchbox/router? Could be a bad port
      Have you run a continuous ping test? To do this go in to command prompt and type
      ping XXX.XXX.XXX.XXX -t
      replaces the x's with the IP of your printer.
