Color laserjet 4700 transfer belt message
  • nathicana
    • Aug 2008
    • 329
    Replaced ETB transfer unit and the message keeps blinking that it needs to be replaced. I have the manual and it doesn't refer to a way to reset the parts counter. The machine was off when the unit was replaced.
    How do I get the message "Replace transfer unit" to go away?
  • Wild Bill
    • Jul 2005
    • 774
    Re: Color laserjet 4700 transfer belt message
    Gotta replace the ITB or modify with a fuse. I just change itb not worth the BS.
    Izzy
    • nathicana
      • Aug 2008
      • 329
      The belt assembly was replaced yet the message did not go away. It was a refurbed belt unit, may have to replace again
        since you had it powered off when Installed... open front door .. power off and back on if that doesn't work follow what Wild Bill said.
        • Lance15
          • Jun 2015
          • 1083
          I don't EVER replace CONSUMABLES/SUPPLIES using refurb parts.......EVER. I don't replace SUPPLIES, period! We work on printers, not copiers.
          If you want to go cheap, reap the drawbacks.
          They do make a device that will reset a belt if it was refurb. Use Google.
          • Wild Bill
            • Jul 2005
            • 774
            Ye get another one cause you purchased it right? They Should stand behind their product. I have had 2 of those Refurbs take out the DC Controller, I think they put the wrong fuse in.
            Izzy
              I NEVER EVER use a refurb'd belt !
              • Wild Bill
                • Jul 2005
                • 774
                I wouldn't either especially toner cartridges! but That's what my employer
                provides so I'm in that position, I think there are many among us that are.
                Basically I wouldn't have anything to do if they were using OEM Fusers and Toners,
                So, in a way they help with job security,lol
                Izzy
                  we use the MSE brand of refurb'd toners.. very few failures ( bout the same as OEM +/- 1% ) but as far as refurb'd belts NEVER Liberty Parts does a great job with fusers .. but they don't sell refurb'd belts either.
                  • zoraldinho
                    teacher-guide-expert-guru
                    • Mar 2008
                    • 5005
                    Try without resistor or by a new resistor. Cheap stuff.
