HP Designjet T2300
  • BEBEDELFUTURO
    • Jul 2017
    • 34
    HP Designjet T2300
    the plotter hpt2300ps not ends of charge, stays in 94% and not progresses, not find the solution to the problem. thanks
  • Kiran Otter
    • Dec 2013
    • 1100
    Re: HP Designjet T2300
    Is the printer making a constant clicking noise?
    Turn the power off and remove all of the print heads. Turn the printer back on. It should initialize now.
    Check the bottom of the print heads for the plastic coming off. I believe it causes interfence with the service station.
    Kiran
    • Lance15
      • Jun 2015
      • 1073
      Like Kiran said. Take all printheads out and install one at a time when asked after a power cycle. Have come across this twice and it seems a printhead is always to blame. Either bad or expired. I was also told by HP to remove the paper when I called about a "stuck at 94%" issue.
      T790, T1300, T2300 - Stuck at 94% During Initialization.pdf
      Firmware update doesn't hurt either.
