HP Color Laserjet M651 Error 13.B2.D2
  • copyguy69
    • Feb 2016
    • 94
    Replaced one of the toner motors and cleaned the printer. Now I am getting the error and no paper will feed from tray 2. Went over all connections twice and double checked everything I touched. Took off the paper cassette front so I could see in and it looks like the primary feed roller is not dropping down to even try and feed the paper and it does not rotate. Any suggestions are welcome. Thanks in advance
    copyguy69
  • Lance15
    • Jun 2015
    • 1089
    Re: HP Color Laserjet M651 Error 13.B2.D2
    Pickup assembly. Just did one of these a couple of weeks ago. In my case, it turned out a piece of plastic that held a spring in place inside the assembly broke.
    • Metrofuser
      • Sep 2017
      • 22
      copyguy69
      Have you checked the connector at J115 on the DC Controller PCA? that's where the pick up assembly gets plugged in.
      Thanks!
      Will at Metrofuser.com
      • HP Remanufactured Printers
      • OEM and Compatible Printer Parts
      • Printer Repair Training
      • Laser Printer Technical Support
      908-245-2100 New Jersey & California
      • Metrofuser
        • Sep 2017
        • 22
        Also you can test the motor function in the component test section of the troubleshooting menu
        Thanks!
