hp 9040 n part needed
  • ps22sp
    • Aug 2014
    • 83
    did anyone have the part number hp 9040n
    the part is :gear to drive fuser ....gear needed
    thanks
  • Lance15
    • Jun 2015
    • 1088
    Re: hp 9040 n part needed
    Sounds like what you need is:
    RG5-7789 - Fuser Delivery Drive Assembly
    • pc123321
      • Dec 2012
      • 103
      i hear the noise when warm up and check fuser jam removal a gear rg5-5700-0000cn
        a photo of the part you need would help
        is it the gear on the blue jam clear knob?
        • ps22sp
          • Aug 2014
          • 83
          when warm up fuser warmup rg5-7789 gear push down touch blue jam clear knob gear ,and then drive the fuser gear to rotate
          noise come from rg5-7789 white gear and rg5-5700-000cn (blue jam clear knob gear
          is that right ?
          • Lance15
            • Jun 2015
            • 1088
            Gears are typically part of assemblies (there are some exceptions). You need to order the assembly that contains the gear(s) you need and either replace the assembly or tear apart both assemblies to replace gears (not advisable)
            RG5-5700 - Fuser JAM Removal
            They are whole assemblies that contain all the parts required for a full assembly swap.
            • pc123321
              • Dec 2012
              • 103
              RG5-5700 - Fuser JAM Remorg5-7789
              warm up noise :
              gear teeth to teeth dirt in grove gear to gear did not match ,there is some distance between them
              i took out fuser deliver drive assembly ,clean the teeth and gear motor rh7-1622 to see there is any noise ,
              • ps22sp
                • Aug 2014
                • 83
                Originally posted by pc123321
                warm up noise :
                Gear teeth to teeth dirt in grove gear to gear did not match ,there is some distance between them
                fuser gear worn
                replace a refurbish fuser ,it work no noise found
