the Cyan toner does not print correctly. cp3530fs
  • kukisek
    • Jun 2025
    [Misc] the Cyan toner does not print correctly. cp3530fs
    Hello. I have a problem with the hp cp3530fs printer.
    Toner from cyan color prints only in the area of 50% of the page on one side.
    I exchanged for a new toner but still the same even a little worse.
    I checked all the toners, fuser, transmission belt in another printer (cp3525) and they work properly.
    anyone help?
  • Lance15
    • Jun 2015
    • 1086
    Re: the Cyan toner does not print correctly. cp3530fs
    Genuine HP toner or aftermarket?
      anyone help?
      [ATTACH=CONFIG]39185[/ATTACH]
      sounds like the scanner glass has a buildup of toner on it ... clean it.
      do a 'stop test' or 'half page test' see if there is image on the belt and make sure it is dense enough
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5005
        Yeap...It Looks like on many colour printers.Dirty glass,polygon mirror or any other mirror...
        • kukisek
          how to clean polygon mirror? and where it is?
          • Lance15
            • Jun 2015
            • 1086
            Print the PQ Diagnostics pages. If cyan is the only color that looks like that, replace the cartridge with an HP cartridge. Never heard if OEM carts are being used or aftermarket.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4621
              have to remove the laser unit to clean polygon motor, etc. Download service manual on google and follow removal steps.
              • Laserrick
                • Oct 2014
                • 13
                If the laser scanner was dirty or blocked the blue fade would be consistent down the page. Because the line is inconsistent and fades from side to side it is a high voltage problem. A stop test (easier to run from the bypass tray) will show if it's an image development (problem is on cartridge drum), primary transfer (problem isn't on cartridge drum but is on ITB) or secondary transfer problem (problem isn't on drum or ITB).
                • Lance15
                  • Jun 2015
                  • 1086
                  The OP NEVER replied if they are using GENUINE toner or aftermarket, NOR if they examined the PQ Diagnostics pages as I suggested. They have either abandoned this post or fixed the issue.
