Faded print on HP Color 4600
Re: Faded print on HP Color 4600
Black PQ page is perfect. That would rule out laser assembly and black toner.Comment
Nothing unusual font-wise. Common fonts like Times New Roman and Arial.
Another detail: my client converted an MS Word document (simple one page letter with a common font) to pdf, and THAT pdf had the fading, as well. Other pdf documents not converted from Office print perfectly.Comment
Where is this setting? I cannot find it anywhere in the properties or preferences in the installed printer on my laptop. And should composite black be on or off?Comment
well seeing how all drivers are not formatted the same ( fields ect ) it could be in the Document properties or the driver... since you didn't even let us know what OS they are running ..... what drivers they have installed and using .... kinda hard to tell you where EXACTLY to lookComment
Your using the UPD, yes? Pretty sure starting w/ Win7, the UPD was the main driver to use. Maybe try using an older version of the UPD (5.5 or so). Have found older versions work better with older printers.
Sent from my SM-G955U using TapatalkComment
Since printing issue is happening with two different computers, let's look at the printer itself.
Make sure economode is off.
Did you do a cold or NVRAM reset?
Did you swap the black cartridge to a color slot and a color cartridge to the black slot and print a document
To do this, go to the Diagnostics Menu and select Disable Cartridge Check. Now you can move cartridges to different slots.
Remember to exit this mode when you are done.
Try using the black cartridge only and leave the color cartridges out or use a color in the black slot and leave the rest out and
print a document.Last edited by Printerdude; 04-26-2018, 10:01 PM.Comment
While in PQ test mode, did you swap the black cartridge to a color slot and a color cartridge to the black slot and print a document?
print a document.Comment
