HP 4555, jams at fuser, but only from 2 trays.
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    It is the full size MFP. Has the tray3,4 and 5 tray assembly. It will jam the paper as it comes out of the fuser, the exit assembly never biting it. When you go into paper path test, it only jams from trays 3 and 5. I had a fuser so I swapped it, no change. I am having a feed assembly and board sent for the tray assembly but I wanted to know if anyone had seen this before.
  • Lance15
    • Jun 2015
    • 1088
    Re: HP 4555, jams at fuser, but only from 2 trays.
    Sticky solenoids in those trays?
    • Wild Bill
      • Jul 2005
      • 774
      Does it give an error?
      Izzy
      • Laserrick
        • Oct 2014
        • 13
        What is the jam code? Does it jam if you run a single sheet or only on multiple copy jobs? Firmware updated? (Firmware MUST be done with trays attached).
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          The firmware was fresh. I replaced the gear pack for the trays, the rollers and the control board for the trays. It works now. Sorry I can't remember the jam code, but when I gave it to tech support and he looked it up, he was looking at the mail bin. I swapped it. I called back later, talked to a different tech, he sent the boad and gear pack.
