Z3200 ps 44-in will not boot up
  • niceville318
    • Feb 2014
    • 43
    [Misc] Z3200 ps 44-in will not boot up
    Current problem is this: Turn the power on and the machine starts booting like its supposed to. Once the count-up hits 17% it just sits there.
    History: a month ago the belt shredded, up until then it worked without a problem. I replaced the belt and tensioner assembly. Had the customer replace "bad printheads". Started getting 86:01 codes after that. I never could get it to pass the scan axis or carriage calibrations. But it did print excellent color documents and internal images.
    So a week after delivering it back to the customer it will not boot past 17%.
    any ideas?
  • tinkerprinter
    • Jun 2018
    • 17
    Re: Z3200 ps 44-in will not boot up
    Maybe just bootup in "Diagnostic Mode" and do an Unsecure ERASE to wipe the drive and have it reinstall firmware.
    • Lance15
      • Jun 2015
      • 1088
      Remove the roll and all printheads and power cycle the plotter. Install the printheads when asked. Had a similar issue and this fixed it. It could be a faulty printhead.
      • Kiran Otter
        • Dec 2013
        • 1114
        I agree with Lance; remove the print heads, and the ink cartridges.. see if it powers up.. then install the supplies again.
        If you're having 86:01 errors, check the encoder strip for damage. Clean it if you haven't already.
        Kiran
        • theengel
          • Nov 2011
          • 1784
          And don't forget that spacer.
