Color laser jet m577. 59.F0.00
  • Wild Bill
    • Jul 2005
    • 774
    Got error wrong it 59.00.f0
    No itb motor, this machine is completely different than previous boxes. . before I strip things down any body see this?
    Izzy
  • Lance15
    • Jun 2015
    • 1089
    Re: Color laser jet m577. 59.F0.00
    59.00.F0 Description
    T1 alienation mechanism failure
    1. Turn the printer off, then back on.
    2. Make sure that the ITB is correctly installed.
    3. Use the manual sensor test to verify that the T1 roller alienation sensor (SR5) is properly functioning. If it is not, replace the T1 roller estrangement detect PCB assembly. PN: RM2-7157-000CN
    4. Use the component tests T1 roller engagement and disengagement drive test to verify that the T1 roller disengagement mechanism is properly functioning. If it is not, remove the ITB and manually actuate the alienation mechanism. If it fails, replace the ITB. If the ITB is working correctly, replace the fuser drive assembly.
    5. Reconnect the connector (J15) of the T1 roller alienation sensor, connectors (J2504 and J2502) on the high-voltage power supply T PCA and connector (J131) on the DC controller PCA.
    • Lance15
      • Jun 2015
      • 1089
      Hey Bill
      Here is a more in-depth explanation of how to troubleshoot this error. It is from the CPMD. The way HP does CPMD's now is stupid. The only way I could get this is by doing screenshots. I've tried many times to create a PDF. Been unsuccessful. Good luck!
      59.00.F0.pdf
      • Wild Bill
        • Jul 2005
        • 774
        Used diagnostics or component test to do a manual sensor test. All sensors except alienation cam sensor.
        SR5 is working. I'll let you know. Another tech is working on it
        Izzy
