30.03.45 Scanner failure - HP LaserJet 700 color MFP M775
  • ecnereht
    • Sep 2018
    • 40
    Hi All,
    Please help us with our printer having error
    30.03.45 Scanner failure.
    Thanks!
    TSL
    • 23002
    Re: 30.03.45 Scanner failure - HP LaserJet 700 color MFP M775
    hmmm ... what would I do?
    Well first I think I would look up the code. Next I would TRY SOMETHING!!!
    Then if I wasn't making any progress I think that I would make a forum post which listed what I found in the manual, and what I tried, and what I theorized.
    As far as I can tell you haven't done any of these things yet. =^..^=
    • ecnereht
      • Sep 2018
      • 40
      Actually, I tried even clearing the errors, reinstalling the firmware, etc. I expect someone from this forum will help or maybe experience the same problem and share here..that's all..
      Thanks for the opinion.
      TSL
        • 23002
        That works better than mind reading, doesn't it?
        What does the manual say? I read it, and I think it will help you too. =^..^=
        • ecnereht
          • Sep 2018
          • 40
          It says, everything you need to know is in the manual.. great! nice suggestion!
          Thanks anyways.
          TSL
            he never does.
              Thanks anyways.
              TSL
              no! that's NOT what he is saying... the manual can be the STARTING point for ideas an suggestions. The problem IS.. you never read or try what's in the manual and NEVER take suggestions from others! MIGHT be WHY your REP POWER is so LOW!
                • 23002
                Sorry. I refuse to read the manual to you. I do not read for people capable of reading for themselves.
                You're a tech. Your job is to read manuals. Read the friggin' manual. It tells you exactly what you should do. I hope you don't really need a forum post to tell you this.
                I'm actually trying to teach you that you are capable of doing this all by your self. You really don't need a solution on a silver platter. You really can think ... I think. =^..^=
                • Lance15
                  • Jun 2015
                  • 1086
                  Hmmmmmmm.....maybe?
                  I work with two people just like this. They think I've got the answer for EVERYTHING and don't want to try and figure something out for themselves. Makes me SICK!!! Great work ethic.
                  • stsacer
                    • Oct 2013
                    • 7
                    Why don't you treat each question as if it was your Grandmothers question instead of being condescending and self righteous.
