hp dj 510 plotter
  • 1stcavvet
    • Apr 2015
    • 231
    [Misc] hp dj 510 plotter
    I need to get new inks for this plotter right now all the colors are # 82---- the black is a # 10 can I put a black 82 in place of the black # 10.???
    • 23010
    Re: hp dj 510 plotter
    Yes. The #82 is the updated supply number. #10 is the original supply number. Just be sure that the ink isn't expired. It will not print, even if the cartridge is full. =^..^=
    • theengel
      • Nov 2011
      • 1784
      I did not know that... is there a way around it? In the past, I've always used expired supplies.
        • 23010
        Not that I'm aware of. I just got done reading a dozen reviews on Amazon about how their discounted ink cartridges were expired and wouldn't do a thing. =^..^=
        • Kiran Otter
          • Dec 2013
          • 1116
          Were they HP inks, or some refilled/third party? I've never had a problem using 'expired' inks in any Designjet printer.
          I also hope people understand; the ink isn't 'expired'. What's expired is the warranty with HP. Once the date on the cartridge is eclipsed HP will no longer honor the warranty on it if it's defective. There's nothing wrong with the actual ink inside the cartridge. I've seen 10 year old inks and printheads work just fine.
          Kiran
          • theengel
            • Nov 2011
            • 1784
            There was that recent firmware upgrade because printheads expiring after 2000 wouldn't work. I wonder if they messed with the printer and made it so that expired inks wouldn't work.
            • D Hook
              • Mar 2018
              • 205
              I did the firmware upgrade and the expired ink carts still work just fine.
              I've not heard of expired inks refusing to print on Designjets. Thought that was only Epson that does that.
