Designjet T2530 - error 86:01 and 86:11
  • kuby
    • Oct 2007
    • 1400
    Have a machine giving 86:01 and 86:11 scan axis errors. Have run the tests for the Star wheel and the PRS and both check OK. But when running the Scan Axis it says FAIL with a Paper Jam/Scan Length error. Have replaced the Carriage PCA w/ Line Sensor Cable and still error. Can not see any paper in the machine at all. Am I missing something or any body seen this before. Thanks
  • Lance15
    • Jun 2015
    • 1088
    Re: Designjet T2530 - error 86:01 and 86:11
    Try cleaning the encoder strip. It sounds like it could be dirty.
    • kuby
      • Oct 2007
      • 1400
      Yea I cleaned the strip several times, oiled the carrier shaft, made sure the carriage moved freely. Inspected the belt, motor, etc.
      Did a Perform an EEROM reset and upgraded the firmware. Still having the same problem.
      • Kiran Otter
        • Dec 2013
        • 1109
        Then you need to replace the encoder strip.
        Kiran
        What a damaged encoder strip looks like from a Designjet
