Re: Black strip on copy plotter HP T2300ps
Hello.
Today the defect did not appear. I tried the calibration 4 times for the service mode. All 4 attempts failed. I did everything that says the manual. There is no dirty glass or the standard sheet shows dust or scratches. I will wait for the return of the defect to change the CIS Element A to another. If the track changes, I'll make sure the fault is in the LED. I'll come to suspect cable flat as well. I can not wait to definitely find the cause of the defect. Thank you very much for your contribution.
Hello.
