There is a pattern in both event logs, the M602 & M604.
From the M602
Entry number 50 event 40.08.00 secure file erase is disabled cycles 54836
#49 32.08.A3 Normal boot up
The next one is save/recover status OK, next would be firmware install error.
Before that#46 said normal shutdown, it goes through this cycle again and maybe
two more times then it shows a late fuser jam from tray 2
Does that cycle once and shows that late to fuser jam. 13.B9.D2
I will try and get this scanned and post it.
Both of these units are doing this. I'm beginning to suspect a power problem or network problem.
Has anyone ran in to this before?
DR
