HP M602 & M604 jammimg when I'm not there, event log pattern
  • Desert Rat
    • May 2008
    • 1089
    [Jamming] HP M602 & M604 jammimg when I'm not there, event log pattern
    There is a pattern in both event logs, the M602 & M604.
    From the M602
    Entry number 50 event 40.08.00 secure file erase is disabled cycles 54836
    #49 32.08.A3 Normal boot up
    The next one is save/recover status OK, next would be firmware install error.
    Before that#46 said normal shutdown, it goes through this cycle again and maybe
    two more times then it shows a late fuser jam from tray 2
    Does that cycle once and shows that late to fuser jam. 13.B9.D2
    I will try and get this scanned and post it.
    Both of these units are doing this. I'm beginning to suspect a power problem or network problem.
    Has anyone ran in to this before?
    DR
  • OMG
    • May 2016
    • 31
    Re: HP M602 & M604 jammimg when I'm not there, event log pattern
    I would move them to a different power outlet just to rule that out.
    We had a issue where the customer was getting the 13.B9 error code. It turned out to be the Cartridge World rebuilt cartridges they were using.
      We had a issue where the customer was getting the 13.B8 error code. It turned out to be the Cartridge World rebuilt cartridges they were using.
      Cartridge World.... yeah had a customer using that shit.... boss canceled maint agree because they REFUSED to use better supplies and tried to blame the crap on me.
      • Desert Rat
        • May 2008
        • 1089
        OMG & Phil,
        Thank for that tip on the cartridge. This company sub contracts me to service these printers for their customer.
        They have their own brand of cartridge and I have seen them cause problems before. In this particular case,
        one of the printers had a staples cartridge the other had their brand. Both are re-manned units. I will look
        in the cost of an OEM for the one of the machines. The M602 is going to be replaced at the customers
        request.
        I will bring this point up to those who send me out on these.
        DR
        • kgodbolt15
          My crew has also run into some fuser late jams that were caused by a faulty tray 2 pickup solenoid that sticks. If that is the case in your situation, it is a cheap & easy fix!
          • Desert Rat
            • May 2008
            • 1089
            Does it have a rubber pad to dampen the click noise? I have seen this in several models of copiers and printers. Wish I'd thought of that
            when I was there.
            I will see if I can check on that should it return. And I found out this end user generally get there cartridges from staples.
            thanks for the post
            DR
              Originally posted by Desert Rat
              Does it have a rubber pad to dampen the click noise? I have seen this in several models of copiers and printers. Wish I'd thought of that when I was there. I will see if I can check on that should it return. And I found out this end user generally get there cartridges from staples. thanks for the post DR
              Hey DR,
              Here's a USA based toner reman company I have used in the past .. very good reliability and warranty
              Welcome | MSE
              and another here in NC:
              Customer Portal - Static Control
              scc also have toner cart chips....
              • Desert Rat
                • May 2008
                • 1089
                Thanks Phil, I will pass this on to the company that sent me out and save it for myself
                as well. Never hurts to have another source.
                DR
