Enterprise M607 jam tray one, the solenoid fires but feed roller does not spin?
  • Kim Krell
    • Aug 2008
    • 43
    [Jamming] Enterprise M607 jam tray one, the solenoid fires but feed roller does not spin?
    I hear the solenoid fire but the feed roller does not move,then says Jam 13.XX tray one??
    Re: Enterprise M607 jam tray one, the solenoid fires but feed roller does not spin?
    jam 13.xx doesn't give us much to go on...
    are feed tires in good shape?
    are you watching it when you say it doesn't move?
    or is it just no moving PAPER?
    • Kim Krell
      • Aug 2008
      • 43
      I can see the roller does not turn, roller is fine. I hear the solenoid click and the pick up roller does not move.
        • 23002
        Is the roller clipped on? the rollers sit nice and still when they're not clipped to the shaft. =^..^=
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5007
          If you rotate a rooler with your hand, it moves freely? Open and check.
          Sometimes a solenoid plate falls out of position and does not perform its fuction but you hear it.
          • Kim Krell
            • Aug 2008
            • 43
            Thanks, I'm going to bring into shop. This sounds like the problem. I have checked all the simple possibilities, thought maybe this was a problem on this mdl and others had seen it. Thanks
