Hp 4000/Intermittant Jams from cassette
  • cucuklotz
    • Mar 2007
    • 611
    Hi,
    I have customer with Hp 4000 that every 100 prints or so jams just out of cassette as it starts to feed.I have replaced, pickup and sep rollers, and set of feed tires(all OEM) and SEP totrque clutch. It still misfeeds
    That is the experience I have with machine,Any suggestions would be appreciated.
    Thanks, ANDY
  • prntrfxr
    • 1622
    If its jamming before the paper feed asm, try replacing the paper p/u asm.
    RG5-2672 500-SHEET P/U ASM
    RG5-2683 250-SHEET P/U ASM - UPPER
    RG5-2684 250-SHEET P/U ASM - LOWER
    If its jamming at or after, could be paper feed asm, registration sensor block (sensors and flags - a bear to replace as its under the engine board), or registration asm.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      If that does not work you could try swapping the paper tray with another, because sometimes the guides can get worn and loose.
        • 23009
        I seem to recall a 4050 that the letter tray would pop open all by itself during pickup. The tray has a locking feature molded into the plastic, and this one was worn out. I replaced the tray to fix this problem. =^..^=
        • prntrfxr
          • 1622
          Sorry, forgot about that. Usually 500-sheet tray problem is with blue paper stop at the end. Consists of plastic tabs that slide into a metal leaf spring. These parts can be ordered or you can just replace the tray. A weak spring or defective tabs will cause paper to slide to the back, p/u assembly wouldn't p/u paper and printer would indicate jam or add paper message. It may be your problem and could definately be an intermittant problem. The stop should slide back, but not very easily. Not usually a problem in the T units.
          C3122A 500-sheet tray
          RF5-2760 paper stop
          RB1-8951 leaf spring
