color M570 dead
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    color M570 dead
    Hi,
    On startup, the hp sign appears and then the black screen.
    Only the orange triangle flashes.
    I hear that the Motor normally performs the initial calibration.
    Can Not get into service mode. After changing formatter, the problem stay.
    Who with a similar problem?
  • Lance15
    • Jun 2015
    • 1089
    Re: color M570 dead
    Sounds like there's a scrap of paper possibly stuck in the paper path somewhere (Only the orange triangle flashes.).
    • tech28
      • Jun 2013
      • 434
      Re: color M570 dead
      If you used the same Module in the new formatter, you will be in square one. Change module first, then formatter. Have had black screens before, has been screens though. Good luck.
      • zoraldinho
        • Mar 2008
        • 5015
        Re: color M570 dead
        Thanks Lance but printer is clean like a charm.
        • zoraldinho
          • Mar 2008
          • 5015
          Re: color M570 dead
          By module did you mean memory dimm? This model don't have any..
          • tech28
            • Jun 2013
            • 434
            Re: color M570 dead
            No, it's the module that goes where the HDD would normally go, machine will not work.
            • tech28
              • Jun 2013
              • 434
              Re: color M570 dead
              Without it.
              • Lance15
                • Jun 2015
                • 1089
                Re: color M570 dead
                Huh? I'm confused. Can you explain what you are talking about? I don't even see a HDD option for this model.
