HP P4015 envelope print smears
  • gideon
    • 283
    Facts: OEM toner (and compatible), OEM fuser (and compatible), uptodate firmware.
    When envelopes are fed through tray 1 there is no problem.
    problem: When envelopes are fed through envelope feeder the print get smeared and double image.
    Any idea?
    • 23010
    Re: HP P4015 envelope print smears
    Any idea?
    What media type is selected?
    • gideon
      • 283
      Media is envelope #10, fuser option - high 2 (and every other fuser option)
      Any idea?
        • 23010
        What media type is set for tray #1?
        • gideon
          • 283
          Media type in tray 1 is "any type" and any size.
            • 23010
            According to what I've read envelopes should fuse properly like 75-90gsm media. That's across several several manufacturers, including HP. High2 is too hot. When you select Any Type, you allow the printer to identify the correct media type and implement it.
            You'll get very similar results from selecting too cold a media type and from selecting too hot a media type.
            • yourownfree
              • Dec 2007
              • 474
              For me I set tray 1 for envelopes, customers computer to choose envelope. I think its going too fast through the fuser. The settings will make machine go slower and give it a bit more heat. The envelope is thicker than a piece of paper and has a fold in it so messes with the fusing of the toner. I think if you set it for envelopes and computer set to envelope you will be fine.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4787
                It has to be set to envelopes so the machine slows down and increases the fuser temp. Most of my customers that feed envelopes use the optional envelope feeder which requires an envelope size be input.
