m607 background
  • johnnyquest
    • Feb 2020
    • 16
    [CQ] m607 background
    i have a newer 607 with grey background. have tried 4 different toner cart, two from working machines. fuser is new, cart is aftermarket.
    anyone seen this? it also had a blank screen when i arrived, but found it plugged into a ups. plugged into wall, started working, but still has background
    Thanks!
    JQ
    Re: m607 background
    Thanks!
    JQ
    you seem to be an end user.
    this is out of your pay class...
    hire a trained tech.
    • johnnyquest
      • Feb 2020
      • 16
      Re: m607 background
      ive heard people on this site are very rude. i am a seasoned tech, but thank you for your time
      • FrohnB
        • Jul 2017
        • 1919
        Re: m607 background
        Make sure all the contacts points on the frame of the machine that contact the cartridge are where they're supposed to be.
        It wasn't a 607, but I had an HP that we tried 3 different cartridges on, and it ended up being that one of the little metal wire contacts was pushed into the frame (not protruding from it) and not contacting the cartridge.
        Omertà
        • johnnyquest
          • Feb 2020
          • 16
          Re: m607 background
          they seemed ok, have you ever had to replace them? im a copier tech thrown into a hospital situation with little printer training
          • FrohnB
            • Jul 2017
            • 1919
            Re: m607 background
            Never have had to replace the contacts.
            Have you tried a different transfer roller?
            Not much else to check. Cartridge, Transfer Roller, Fuser is about all that can go bad.
            Have you tried just running like 30 pages through it to see if it gets better?
            Omertà
            • FrohnB
              • Jul 2017
              • 1919
              Re: m607 background
              After talking with another technician he says, "not to rule out the Print driver". I have not personally run into this (and doubt it's the reason), but something else to look at I guess. Just Uninstall and then Re-install driver on computer. I guess the easy way to check this before uninstalling the driver is to print an internal print (config page, supply status, etc.) if it comes out dirty, then it's not a driver issue.
              Omertà
              • FrohnB
                • Jul 2017
                • 1919
                Re: m607 background
                Afterthought: They aren't using MICR cartridges are they? Hate those things.
                Omertà
                • Lance15
                  • Jun 2015
                  • 1089
                  Re: m607 background
                  Do you have a genuine HP cartridge to try?
                  The fuser can also cause a gray background if it's not getting to temp. Just because the fuser is new doesn't mean it can't be faulty.
                  No replacing the HV contacts. They run through/part of the chassis.
                  Transfer roller is a possibility.
                  Most probable cause are the aftermarket toners.
                  • johnnyquest
                    • Feb 2020
                    • 16
                    Re: m607 background
                    thank you so much for the replies. not micr, internal print has background also. i was able to get IT to place a loaner, so i ordered the power supply and dc cont. i believe this happened when they plugged it into a ups. the display screen was blank and the background happened at the same time. plugging it into the wall seemed to fix the display, but not the background.
                    the hospital will only use aftermarket toners, and it was ok up until this happened. i will update as soon as i install parts.
                    again, thank you so much for the professional replies.
                      Re: m607 background
                      never put a battery back up on a laser or copier.. it will beep every time the fuser fires up and will destroy the batteries after a while
                      compatible/after markets rarely do the job ... fail before EOL
                      • johnnyquest
                        • Feb 2020
                        • 16
                        Re: m607 background
                        agreed. just got the printer on my bench, now working perfectly. no parts, just better power. is this normal for HP?
                          Re: m607 background
                          not just HP.. most brands suggest NO UPS or surge...
                          this is the only surge that MOST companies agree with.. and the provide a warranty
                          SURGEX Power Protection and Conditioning
                          have them get a certified electrician in to check power
                          • buf7579
                            • 12
                            Re: m607 background
                            Thanks!
                            JQ
                            I had an instance a year or so ago, in which a client suite had (4) M607 printers, and all were producing defects similar to what you describe. Conferred with my fellow technicians and managers and nobody could come up with much of anything.
                            With nothing to lose, I did a firmware upgrade on one printer, and that eliminated the background defects. Upgraded firmware on the other 3 printers thereafter, and that resolved the issue on all 4 printers.
                            Firmware for the M607 series can be downloaded here:
                            HP LaserJet Enterprise M607 series Software and Driver Downloads | HP(R) Customer Support
                            • johnnyquest
                              • Feb 2020
                              • 16
                              Re: m607 background
                              I Really appreciate the replies. so far ive had 3 607s with the same symptoms. the last one i replaced the lvps, which seemed to fix all of them. i did try firmware, but perhaps that should be done proactively. THANKS!
