HP PageWide Managed Color MFP E77650
  • bobburnsreb
    • Mar 2015
    • 233
    Just setup or first HP and during testing couldn't figure out how to eject the usb thumb drive. Is it safe to just pull it out or is there something I'm missing. Couldn't get an answer from any of the manuals/WISE. Thanks in advance, Bob
    Re: HP PageWide Managed Color MFP E77650
    i take it you were doing firmware or such?
    did it finish successfully ?
    if the light on the USB is out. then remove it.
    really should have explained what the issue was and the results.
    IMHO the pagewide printers were crap.. the printbars failed WAY before time even with Genuine OEM inks. And the were a bitch to replace.
    • bobburnsreb
      • Mar 2015
      • 233
      I was just testing print from usb from the walk up port. I don't see an eject option after job completion. I'm with you on the pagewide feelings. Hopefully this trial only goes as far as the demo room.
        like I sad if light on USB is out yank the stick
          • 23008
          I've never been able to find an eject function. These are some of the most user unfriendly machines I've ever seen. =^..^=
          • tsbservice
            Field tech
            • 8013
            Afaik Konica Minolta and Brother printers also don't have Eject functions like PCs. Just checked HP manual, also missing this.
            • Zeldaman
              • Mar 2011
              • 946
