Hp DesignJet 5500 cautionary tale
  • Synaux
    • Mar 2012
    • 1224
    The other day I was troubleshooting a bad HDD/PSU.
    It has been a long time ... and that back panel has a very unnecessary cable management system on the left side (looking from the rear). In some frustration, and in the dark, I was slightly more aggressive that I probably should have been and in process of disconnecting the cable-management-fixture-thingamajig, I disconnected 2 of 3 of the "Trailing Cables."
    I reconnected them then kept getting odd PH errors, etc. I reseated and repeated.
    It turns out at this age, these cables cannot be fussed with. The adhesive that kept the leads on the ends of the cables lost all sticktion and were literally fraying and falling off. I had to order new Trailing Cables (not very expensive...but...). So do not do what I did. Keep those ribbons connected!
    Hope this might be in the back of someone's mind when servicing one of these.
    (I know these machines are getting old, but they are honestly one of the most dependable and well engineered old beasts out there.)
  • D Hook
    • Mar 2018
    • 205
    Re: Hp DesignJet 5500 cautionary tale
    I've repaired a few of these and make it a point to never touch those cables either unless replacing them (not fun!). Found out the same way you did. And you're right, those machines are so bullet proof it's amazing, compared to some of the newer models. Parts are still pretty easy to find and consumables are priced reasonably (but you have to shop around for the printheads as those can start to be more than the machine is worth sometimes). They still work with Win10 but takes a little time to get setup. The only problem I've found difficult to solve is loading media profiles but easy if you can get the machine to work on the Web Access feature.
    I'm pretty sure that if I could only own one printer, that would be a close contender for top place.
    Thanks for the reminder.
    • Kiran Otter
      • Dec 2013
      • 1106
      Yes! Absolutely avoid disconnecting the trailing cable on these printers if not necessary. It's very easy to blow either the carriage or main PCA by trying to plug the cables back in and the little fingers going everywhichway (technical term.) It's even worse on the 1050C model A because there's no fuse to protect the main PCA.
      Even if I'm doing a belt on the 5500 or 1050Cs, I'll keep the trailing cable connected, and unfasten the trailing cable holder in the middle of the machine, and if that's not enough, the one where the cable bends and goes down through the aluminum casting, just to avoid disconnecting it.
      Kiran
      • Synaux
        • Mar 2012
        • 1224
        Yeah the cables just arrived and I am NOT looking forward to this job considering the mess they made just taking them out of the package. It somewhat reminded me of when I get fishing lines tangled up. Any sage advice to make this easier?
        I was thinking some electrical tape to keep them together during installation would help?
        It really is amazing how these machines perform. Yes, the PHs are overpriced--in my opinion--for what they are, but there are many ways to recondition them and force them to function far past their prime. Aside from that, I have only had issues with the drive belt (basically a consumable), TCP settings not sticking and now an error with the HDD.
        This is a long winded way to ask my next question... for the HDD, I have read that it is paired with the board it is connected to. This seems crazy to me but ok. The service manual that I have is absurdly vague. And I have never had to do this so please forgive my ignorance. What is stored on the HDD? Is it like many MFPs and doesn't store crucial data like FW, etc? Can I just go find an IDE HDD in storage and swap it?
        Also, the HDD spins and sometimes (rarely) the code does not show and I noticed a message something like "preparing HDD" with success. SOooo I am thinking PSU based on what I have read. Thoughts?
        Apologies, I did not intend to ask so many questions, but the documentation I have is simply not helpful.
        • D Hook
          • Mar 2018
          • 205
          The last time I changed a set of flat cables out on a 5xxx printer, I took some bond paper and carefully wrapped the ends of the cable tightly and taped it to the cable bundle so it would hold the cables together and also protect the ends of the cable when you snake it through the openings down to the PSU. Worked great. You don't want to put any tape on the foil ends of the cables because it might damage them when you try to remove the tape. The only problem I ran into was to be sure the cables moved correctly after fastening them down to the bed of the printer. Some of the cables you can buy come with an new hold down clamp and are pre-folded so they move correctly when the printhead moves. Others come without and are a little more difficult to install, IMO. You can tape them together as you need but be sure to remove the tape before running the printer so the cables can slide as needed.
          Which service manual are you using?
          If the HDD is failing they can be found on ebay for around $75, last time I purchased one. They come preloaded with firmware and media profiles. It's pretty much plug and play. Anyway, that's been my experience. Check the sellers feedback of course and read the description carefully or ask the seller to confirm it's loaded already. Also, be sure you're buying a HDD that matches your model; either a PS model or non-PS. Non-PS will not work on a PS model. If you haven't loaded a new hard drive before, download a copy of the HP service manual https://tonerinkprint.com/5000-5500.pdf (free) and follow the steps. There's a couple things to avoid when you load a new hard drive.
          I'm sure others have additional tips on the repairs. Let us know how you get on.
          • Kiran Otter
            • Dec 2013
            • 1106
            Just a note; it is possible to replace the hard drive with a blank drive, and load the firmware using the parallel port. Of course finding a computer with a parallel port these days might be a problem. I have an old laptop with one I keep around for things like that. If you can get a drive preloaded for $75, that sounds like a deal.
            I found a thread on HP way back when that talked about it. Dropbox - Installing a new blank hard drive in a DesignJet 5...pdf - Simplify your life
            I also want to note; 9 times out of 10, when I've encountered a 5500 that says the HD failed, it was the power supply, not the hard drive.
            And replacing the trailing cables isn't that difficult. I pull the old ones out, lay them out on a table, and bend the new ones to match, swapping over the holder and stiffener. Just make sure the length from the holder to the carriage is the same. If it's too short, it won't reach the carriage when it's all the way to the left, and if it's too long, the stiffener won't keep with the cables correctly. You have some wiggle room where they snap into the top of the carriage, so once it's done, you can pull the loop of cable and stiffener to the right (away from the carriage) to bring them all together, and then they'll track back and forth together correctly.
            The last cable I got which was just the flat cable rolled up in a bag, was almost a foot longer than the original. I left the extra length at the main PCA end and just let it run down and back up to the connectors. I ignored the cable holder with the ferrite thing.
            Kiran
            • Synaux
              • Mar 2012
              • 1224
              • Kiran Otter
                • Dec 2013
                • 1106
                Personally I'd get the pre-formatted drive mentioned on ebay and save the trouble of doing the process I mentioned. I just mentioned it since we were talking hard drives. But I'd replace the power supply first.
                Also you can still buy a new PSU from HP. They're still in stock, amazingly enough. $266.19
                Kiran
                • Lance15
                  • Jun 2015
                  • 1086
                  And in an incredible white PCB!
                  • tonerjockey
                    • Apr 2014
                    • 567
                    thanks for the heads up. i hate when things like that happen. and never a good time.
                    have a great Holiday.
                    • Synaux
                      • Mar 2012
                      • 1224
                      • Synaux
                        • Mar 2012
                        • 1224
                        Ok guys, I got this dinosaur up and running.
                        It was the PSU.
                        Some notes:
                        I thought I was being a genius by hot-wiring a computer PSU to the HDD with the HP PSU connected to everything else.
                        If you do this with a lack of the 12v from the HP PSU you will (or I did) get a Trailing Cable not installed correctly error (sorry I forget the exact wording/error code). This of course made question life until the new PSU arrived from over the pond.
                        On a side note, I noticed that there was air in most of the lines on the carriage side. I used a syringe to get it out and ordered a set of the nozzles that the printheads insert into. Any other suggestions?
                        Also, the HDD had something like 5-6 partitions, I do intend on mirroring the drive or using the guide posted earlier to make a backup drive as a precaution (if I ever get to it).
                        • Kiran Otter
                          • Dec 2013
                          • 1106
                          Congrats on getting it running. That's interesting about the 12V and powering the drive independently, I would have assumed that would work. I guess the 12V rail does more than just power the hard drive.
                          I wish you luck trying to replace just the ink plenums for the carriage. Let us know how that goes. I've always just replaced the tube assembly as a whole.
                          Kiran
                          • Synaux
                            • Mar 2012
                            • 1224
                            Kiran
                            Yes, and the 2 LEDs on the back of the machine seem to represent the 12v and the 5v. I tried manually applying 12v to the HDD power connector for a second. The lines got super hot and let a bit a smoke out but the LED that wasn't lighting, lit up (I suspect the old PSU was creating far too much resistance hence the heat)
                            This method could possibly be a fix for a lack of 12v but is for someone braver than me (e.g., eliminating the 12v lead from the PSU and supplying it manually).
                            The plenums are fairly easy to replace. That I have done before. The only issue is trying to get the old ones off without having to cut the tubes and thereby shortening the tubes.
                            • Kiran Otter
                              • Dec 2013
                              • 1106
                              You should make a video of replacing the plenums, if you can. I'm sure that would be useful to a lot of people.
                              Kiran
