Hi Folks,
i have several M577 Maschines who makes a fine line at the end of the Page when you are
using the document feeder.
Means: Make a copy of an original with the DF and you will see at the end of the Page a fine line,because
the DF copys the Paper too fast and the copy is smaller than the original. You will see the end of the Paper.
I changed the Firmware and adjust and calibrate the Document Scanner,but nothing helps.
Any ideas ?
See the example.
DFScan.pdf
Cheers
Roger
Any ideas ?
See the example.
DFScan.pdf
Cheers
Roger
