M577 Df Scan
  • Roger67
    • Nov 2013
    • 84
    M577 Df Scan
    Hi Folks,
    i have several M577 Maschines who makes a fine line at the end of the Page when you are
    using the document feeder.
    Means: Make a copy of an original with the DF and you will see at the end of the Page a fine line,because
    the DF copys the Paper too fast and the copy is smaller than the original. You will see the end of the Paper.
    I changed the Firmware and adjust and calibrate the Document Scanner,but nothing helps.
    Any ideas ?
    See the example.
    DFScan.pdf
    Cheers
    Roger
  • Michael
    • 158
    Re: M577 Df Scan
    hello Roger,
    it looks like if some zoom in and out functions are enabled? the print in the pdf seems to be to much left not only the line at the bottom.
    this print is not a real good test..
    i would print a whole sheet with only "A" Letters. then you can see if the letters at the begining of the page and the end of the page have same size. the same from left to right. messure this.
    My profile is not working at the moment. The profile you see is not mine. Board redirects to a wrong userprofile. So you CAN“T REACH ME over the profile via SEND PRIVATE MESSAGE and even not over regular Email too
    You only can contact me if you click my name on a post and select PRIVATE MESSAGE straight from there.
      • 16312
      Re: M577 Df Scan
      Draw some registration marks on a blank sheet and send back the results. The page you're using isn't very helpful. See image below:
      test.pdf
      • tsbservice
        Field tech
        • 7980
        Re: M577 Df Scan
        [ATTACH]47699[/ATTACH]
        Didn't make it from a long time. That's what I used when learning copiers and have to test DFs.
        You only missed the arrow in the middle pointing paper traveling. Now carry one of KM DF setup charts, pretty much the same like one you can draw in 10 seconds.
          • 16312
          Re: M577 Df Scan
          I was being lazy and didn't feel like explaining the paper direction arrow. I'm guessing the OP doesn't have a lot of experience or he would have scanned a better original that would have told us something.
          • Michael
            • 158
            Originally posted by Michael
            hello Roger,
            • tsbservice
              Field tech
              • 7980
              Re: M577 Df Scan
              I understand what OP means but I feel a bit biased against newer HPs. Everything I touched was a POS.
              Maybe someone with access to tech bulletins can come up with something more useful.
                • 37365
                Re: M577 Df Scan
                If it is also cutting off the lead edge, I would suspect that there is a problem with the document feeder paper path sensor 1. If there is a speed difference I would say that either the feeder, the engine or both are set for the wrong paper thickness.
                  Re: M577 Df Scan
                  I agree the newer HPs are crap.
                  • Roger67
                    • Nov 2013
                    • 84
                    Re: M577 Df Scan
                    Hi Folks,
                    thanks for your answers.I now these Test-Sheets witth the arrows.
                    I work since 30 Years on Printers and Large Format Printers and i cant remember to
                    see that kind of primitive Products like these HP Printers,which a have to deal with in the last 2 month
                    while i need to change the company.
                    I am in christmas holiday now,and i will send you an example of the Arrow-Test-Sheet a little bit later.
                    Merry christmas and a happy new year.
                    Roger
                    • tsbservice
                      Field tech
                      • 7980
                      Re: M577 Df Scan
                      Hi Roger,
                      Primitive is the word I would love fo copy from your description when talking about those HP products
                      Happy holidays to you and your family.
                      • Roger67
                        • Nov 2013
                        • 84
                        Re: M577 Df Scan
                        Hi Folks,
                        so,back to work again.
                        In the Attachment i send you a copy of a Test-Sheet using a Paper with the Arrows.
                        You can clearly see,that the copy is smaller than the original,but only when you are using the DF.
                        Arr2.pdf
                        Still don't now,why this happens......
                        Cheers from Switzerland
                        Roger
                        • Roger67
                          • Nov 2013
                          • 84
                          Re: M577 Df Scan
                          Hi Folks,
                          I can't believe that !
                          621 views and nobody has an idea ?
                          omg
                          Cheers
                          Roger
                          • tsbservice
                            Field tech
                            • 7980
                            Re: M577 Df Scan
                            Did you replace all DF paper feed/pick rolls and clean all miscellaneous rubber rollers along a paper path?
