How to install HP P3005 printer driver on Windows 10 - USB port
  • atadikohp
    • Apr 2017
    • 46
    Windows 10 said driver not available when usb port is connected , but won't allow me to manually point to the HP Universal driver I have downloaded. Any advise?
    • 8136
    Re: How to install HP P3005 printer driver on Windows 10 - USB port
    When you first plug the printer in via USB it should automatically install the correct driver.
      • 30061
      https://support.hp.com/us-en/drivers.../model/1846089
      • atadikohp
        • Apr 2017
        • 46
        Yes Windows 10 did ran thru driver installation process and did create a printer icon in
        printers and scanners page nut show no driver is available and also won't allow me to manually install the driver
        • atadikohp
          • Apr 2017
          • 46
          I did download the HP universal driver but my problem is Windows 10 won't allow me to manually point to that driver location after extract the file
            • 30061
            Go to hp and download the driver
            • atadikohp
              • Apr 2017
              • 46
              I did download the HP Universal driver but windows 10 DOES NOT ave a option for me to install the driver manually
                • 30061
                download the USB driver
                • atadikohp
                  • Apr 2017
                  • 46
                  download the USB driver?????
                  • Lance15
                    • Jun 2015
                    • 1086
                    Unplug the printer. I'm assuming it's connected via USB?
                    Install the UPD using the "USB mode Plug-n-Play" option.
                    This option will copy the drivers into the Driver Store and create a "Universal Printer" in Devices.
                    Plug your printer back in. Go back into Devices and go to Properties on the "Universal Printer", select the USB port (either USBxxx or DOT_4). Make any other changes as wanted (change printer name for easier recognition).
                    • atadikohp
                      • Apr 2017
                      • 46
                      P3005 printer still shown "driver is unavailable" and I have NO option to go to printer property to point to the driver.
                      On this same system I was able to install the HP CP4005DN network using the HP Universal driver but the P3005 USB is not.
                        • 8136
                        You are on the wrong page to change the printer driver.
                        Go to Control Panel\Hardware and Sound\Devices and Printers then you can change the driver etc.
                        • atadikohp
                          • Apr 2017
                          • 46
                          [ATTACH=CONFIG]48382[/ATTACH]
                          So I went to Control Panel\Hardware and Sound\Devices and Printers then right click on the P3005 printer Icon and select property there are 2 tabs but no option on update driver or reinstall driver
                          • Lance15
                            • Jun 2015
                            • 1086
                            When you right click on the printer in Devices, select Printer Properties.
                            Is there a 'Printer Properties' option?
                            If not, go here: HP LaserJet P3005 Printer series Software and Driver Downloads | HP(R) Customer Support and download the USB (DOT4) driver and install it.
                            Unplug your printer, install the USB driver and try again. I've not had to install a P3005 on a Windows 10 machine lately and can't remember if it needed the DOT4 driver installed (I know the 1320's do).
                            • atadikohp
                              • Apr 2017
                              • 46
                              The DOT4 driver DID it. After install the dot 4 driver and re-connect the USB Cable , Windows 10 automatic installed the correct driver. Thank you Lance15!
                              Over 20 years working with all type of printers and I still could not install the printer driver correctly. Isn't it ironic? LOL
