T1300 error 8-11
  • gordie
    • May 2008
    • 83
    T1300 error 8-11
    Hi. Have a T1300 error code 79.04 customer tried to load latest firmware but would not except it.
    By the time a got there the error code is 8.11 checked the lights on the formater and the light indicate a a hard disk fault.
    Can I use an ordinary 160Gb hard drive? If I can how do you load the firmware onto the new hard drive?
    As I have never changed a hard drive before I hope someone can help.
    Regards Gordie
    sigpic
    • 22997
    Re: T1300 error 8-11
    I may be wrong about this ... but I believe that there is no firmware on the HDD, it just needs formatting. You may lose networking data.
    I'll be watching the responses. =^..^=
    • Kiran Otter
      • Dec 2013
      • 1106
      As far as I know the drive is pre-formatted with some initial firmware, which is then updated using a USB stick with the latest firmware on it. I do not believe you can put a blank drive in there but, I've also never tried to do so. Can't hurt to try.
      Kiran
      • gordie
        • May 2008
        • 83
        Thanks for replies, Kiran is right i am lead to believe their is some unix programming on the hard drive. I installed a unix hard drive. The printer booted up to about 20% then asked for usb stick with firmware. printer now working.
        Thanks Gordie
        sigpic
          • 22997
          Good to know. Thanks! =^..^=
          • Kiran Otter
            • Dec 2013
            • 1106
            A 'unix' hard drive? Do you mean one formatted ext4 or something?
            I'm glad (and surprised) it worked.
            Kiran
            • gordie
              • May 2008
              • 83
              Hi as far as i am lead to beleive it had a unix program on the hard drive.
              Gordie
              sigpic
