M605 - Jams First job of the day
    • 22997
    Re: M605 - Jams First job of the day
    Since it occurs on the first job in the morning I wonder if it might be the over night temperature? How long before they arrive in the morning does the climate control system kick in?
    The only time that I've seen this particular situation, was a customer that had the air conditioner on a timer to shut down at 1700 and start back up again at 0800. When I showed up in the morning it was really hot and humid in the summer. I was not able to convince them to change anything, so I guess it must have just continued every summer. They stopped calling about it, and that was welcome. =^..^=
      • 37323
      I had a few problems with the old Aficio 1022/1027 giving SC542 if the ambient temperature was too low at power on. Ricoh released an update to the SBCU firmware that added a SP option to force additional fuser idling time when the temperature was below a certain level.
      I also had a Gestetner 5502, Aficio 1055, at the records office, portable building(trailer), that gave warm up errors during the winter. I asked them to try not to use it until the heat had been on for at least 30 minutes. As they knew my mother-in-law, she used to be their boss, they were willing to comply.
      • sandmanmac
        • 3979
        Well.....I returned the printer today and after explaining that I was unable to duplicate the issue over 3 days and several hundred pages, I powered it up and it jammed on the very first page!
        But this time it continued doing so after removing the paper.
        I grabbed another toner cartridge off the shelf, popped it in, and no jam. Reinstalled the old cartridge..... Jam.
        I did it 4 more times just to be sure, and it did it every single time.
        I can't see anything physically wrong with the drum hub, or gears on the cartridge, and it turns freely by hand, but there's apparently something that's not quite right. Seems that maybe the actuator on the cover possibly isn't seating correctly on that cartridge when yo close it.
        Must admit...I'm a little embarrassed that it ended up being just a toner cartridge, but I've never seen one fail in such a strange and intermittent way before.
        I'm glad it showed up again while I was there ( and not next week), and also became more persistent. It sure makes troubleshooting easier when you can witness the problem, and do things that change the behavior.
        I appreciate all your input and conversation though!
          • 22997
          #19
          Thanks for posting back! Sometimes it's just luck that gets you in front of the machine at the right moment. =^..^=
          • austonrush
            Sharp & HP Tech
            • 234
            #20
            Hey Guys,
            The most common cause of toner jamming on all these newer hp toners is the drum dongle gear. Either the spring pops off, or one of the 2 pins will snap completely. See image below:
            That broken shard will be in the printer after the customer switches the defective toner so, don't assume anything and always take a look for it!
            • jmaister
              certified scrub
              • Aug 2010
              • 755
              #21
              There maybe two problems.... You maybe exhausted and the toner cartridge seem to be the cause due to fatigue and handling of the components. (long day, same problem, calls piling up...so on and so forth).
              the actual problem maybe still there.
              *first jam of the day seldom changes to jam every page...
              ** if one of these days you get there early enough before they print, check for water on fuser exit. Moisture as mentioned warp paper, and warp paper hits guides and missed timing...
              if it had fix it self, then lets never mention this again
              Idling colour developers are not healthy developers.
              • sandmanmac
                • 3979
                #22
                Well it's been five weeks without an issue, so I'm even MORE confident that the issue is resolved than I was when I reported that it had been.
                (And I'm also well rested )
                • jmaister
                  certified scrub
                  • Aug 2010
                  • 755
                  #23
                  oh boy... i didnt check the date...
                  you know what this job does to ya...
                  • hpcom.us
                    #24
                    Download and install free Hp Printer Drivers - www.hpcom.support
                    Hpcom Support Helps HP Printer users to download and install All Hp Printers drivers
