HP DJ T795
  • CP-1015
    • Nov 2020
    • 317
    HP DJ T795
    After permanent error all printheads colleague swapped complete carriage assembly (include PCA and line sensor) without success. Line sensor calibration fails. Carriage Assembly Test: 55:11 No Vpp0 and no Vpp1. Measure up Trailing Cable without finding. Other idee than EE Box? Spezial issue? It's my first T795 I've ever seen. Thanks advance for help.
  • Kiran Otter
    • Dec 2013
    • 1109
    Re: HP DJ T795
    You probably have a bad or damaged trailing cable; I would replace that first. And if that doesn't do it, then the electronics module WITH the power supply.
    In retrospect, always replace the least expensive part in the chain first.
    Kiran
    PS - Was it a new carriage assembly? Or used?
    • CP-1015
      • Nov 2020
      • 317
      Re: HP DJ T795
      [QUOTE=Kiran
      PS - Was it a new carriage assembly? Or used?[/QUOTE]
      Good question. I'll ask my colleague after his holiday.
      • CP-1015
        • Nov 2020
        • 317
        Re: HP DJ T795
        It was new. Is there no possibility for measuring?
        • Kiran Otter
          • Dec 2013
          • 1109
          Re: HP DJ T795
          You mean like checking for voltages at the carriage? You can, but with the nature of the trailing cable constantly being flexed, you may get voltages at one carriage position, and not at another. Plus replacing the trailing cable is pretty simple, and a generic trailing cable is cheap (vs the actual HP part which is stupidly expensive.)
          In my experience the electronics module is the most common failure; either the module itself or the power supply, or both together. Then the trailing cable, and last the carriage. But anything's possible. All 3 could fail together.
          Kiran
          • CP-1015
            • Nov 2020
            • 317
            Re: HP DJ T795
            Kiran
            Ok, thank you! But if measuring on the mother board - where trailing cable is connected?
            • Kiran Otter
              • Dec 2013
              • 1109
              Re: HP DJ T795
              I don't know. In all my years of repairing Designjets, I've never had to determine a problem that way. I wouldn't trust it to supply voltage to something, find a problem, but keep the voltage applied rather than turn it off. Maybe someone else can offer some ideas along those lines.
              In some models there are LEDs to indicate voltages. There is one on the carriage I believe on the T-series, that's about the only indication there is.
              Kiran
                • 23007
                Re: HP DJ T795
                You mean like checking for voltages at the carriage? You can, but with the nature of the trailing cable constantly being flexed, you may get voltages at one carriage position, and not at another. ...
                Kiran
                I suppose that you could clip onto the ribbon contact at each end of the ribbon cable, set you're meter to tone, then repeatedly slide the carriage through it's entire range of movement .. but you're going to spend a lot of time doing this, then not be entirely sure if the cable is good or not.
                I have tried this and was not entirely satisfied with the results. =^..^=
                • Kiran Otter
                  • Dec 2013
                  • 1109
                  Re: HP DJ T795
                  For $15, just replace the cable.
                  Kiran
                  • CP-1015
                    • Nov 2020
                    • 317
                    Re: HP DJ T795
                    Now I swapped trailing cable. Before any justage:
                    22.0:10
                    Error-Code 0x10503005
                    Error: unavailable
                    File: -threadx-opt/elektra/hal/motors/BPA/elektra/BPSStateMachine.cpp
                    Line-number: 327
                    I'd performe IDS/Ink Delivery System.
                    22.0:10 again. Shell I perform Ink Supplies and Leckage, too?
                    Thanks advanced.
                    • Kiran Otter
                      • Dec 2013
                      • 1109
                      Re: HP DJ T795
                      Check the connectors to the electronics module where the ISS is connected. Look for bent pins. Reseat the connectors. Disconnect the ISS at the ISS and see if the error changes. Was there an ink leak? Are the ISS contacts contaminated with ink? Clean them off.
                      Kiran
                      • CP-1015
                        • Nov 2020
                        • 317
                        Re: HP DJ T795
                        After reseat some connectors: 08:04. I tried to rewrite new firmware via usb thumb. Since more than 2 hours initialisize 20%.
                        • Kiran Otter
                          • Dec 2013
                          • 1109
                          Re: HP DJ T795
                          08:04 is very misleading. It's not a problem with the front panel. In my experience it's the hard drive on the formatter board. But it may also be the formatter itself, or the power supply.
                          What happened to this printer that it's having so many problems??
                          Kiran
                          • CP-1015
                            • Nov 2020
                            • 317
                            Re: HP DJ T795
                            Wrong question! Korrect: What I had done that I have to repair this plotter? It's in perfect condition, no ink on connectors.
                            After interrupt firmware update same error as to begin: "Print heads must be replaced individually"
                              • 23007
                              Re: HP DJ T795
                              Kiran
                              I think it was a T2530 ... It kept telling me to re-seat ink cartridges in the right side ISS. Randomly combinations of yellow, magenta, & cyan. I could tell that the enduser had swapped in 3 different yellow ink cartridges, all of which were full. Sometimes swapping in an ink cartridge worked for a while.
                              I ended up re-seating cables to the right side ISS. It seemed to take even longer than normal to initialize ... then the issue was solved. =^..^=
