Hp designjet t790
  • walidcharifi
    • Feb 2011
    • 379
    Hp designjet t790
    Hi friends...
    i have hp t790 no accept cartridg not hp< compatible >
    accept only original
    It used to work with refillable cartridges.
  • Kiran Otter
    • Dec 2013
    • 1115
    Seeing as the firmware hasn't changed since 2023, the problem is likely with the cartridges you're trying to use. This is some of the risk you take using 3rd party cartridges. Perhaps try a different brand.
    Kiran
    • walidcharifi
      • Feb 2011
      • 379
      I don't think the problem is with the cartridges because another printers accepts them.
      .... Could the problem be in the mother card?
      • Kiran Otter
        • Dec 2013
        • 1115
        If it accepts genuine HP cartridges, then I wouldn't suspect a problem with the printer.
        It's impossible to give support for non-genuine consumables. If they don't work, don't use them.
        Kiran
