DesignJet 450C
  • Hansoon
    • Sep 2007
    • 3389
    DesignJet 450C
    Customer has an almost never used DesignJet 450C. Looks indeed like new, even the carriage belt.
    Is there any hope to find a usable driver, generic perhaps, to use it with at least W10?
    Machine has only a LPR port (LOL) What Interface card would it eventually need to hook up LAN?
    Hans
    Re: DesignJet 450C
    Hans
    External jetdirect?
      • 23009
      Re: DesignJet 450C
      12 years back, we had a Designjet 500 that we connected to an ancient Windows 97 PC as a print server, then shared the driver out to the rest of the network. As long as you didn't try to do anything on the Win97 box it was fine. The PC got the idea that it needed updates, and would go into long cycles of trying to do updates, unsuccessfully. I think that's why that PC ended up on the shelf. =^..^=
      • Kiran Otter
        • Dec 2013
        • 1115
        Re: DesignJet 450C
        I have a copy of the X64 drivers for the older series Designjets, but you can't install them on 10 because they're not digitally signed. You can to an F8 boot and disable digital signatures but then you have to do that every time the system boots, I believe. So I don't think it's a viable solution. I'll PM you a link to the drivers though. You can set up a Windows 7 PC as a print server and share the printer to the Windows 10 machine... see what happens.
        Kiran
        • Kiran Otter
          • Dec 2013
          • 1115
          Re: DesignJet 450C
          Just realized the file is so small I can post it right here.
          Kiran
          • Kiran Otter
            • Dec 2013
            • 1115
            Re: DesignJet 450C
            Oh and I don't think that printer had any network functionality. It's parallel only. You can get an ethernet to parallel adapter still, probably.
            Kiran
            • Hansoon
              • Sep 2007
              • 3389
              Re: DesignJet 450C
              Thanks Guys.
              Hans
              • Kiran Otter
                • Dec 2013
                • 1115
                Re: DesignJet 450C
                Btw, when installing the driver, there are two choices for the 450, a D (24") and E (36").
                Kiran
                • Hansoon
                  • Sep 2007
                  • 3389
                  Re: DesignJet 450C
                  Thanks Kiran.
                  Hans
