HP M 281 washed out media
  • tech28
    • Jun 2013
    • 434
    Have a HP M 281 with about 1000 clicks, customer said it just happened to start printing and copying very washed out anything, all colors, using oem toner.
    Determined it has a bad high voltage problem. as in the 377 and 477, the high voltage in integrated into the main pwb. My suppliers tell me the board isn't available from HP?
    Not available! So.. look for a good used one? Machine is about 1-2 years old! So, they want you to throw out and get new one? Just doesn't seem right.
    Any suggestions?
    • 23010
    Re: HP M 281 washed out media
    Since the Covid, quite often we hear about replacement parts that just are not available any more. Machines new, still not unboxed.
    Have you thought about simpler possibilities like moist paper? Have you looked at the latent developed image on the belt to see if it's properly developed? =^..^=
    • tech28
      • Jun 2013
      • 434
      As the transfer is also controlled by the Same pwb. So.. back to square one. No board.
      Thank you blackcat, yeah covy has done much damage to most everything, in one form or another.
      • JR2ALTA
        • Feb 2010
        • 2033
        There is a class of printers (HP especially) that are "throw away". Often even basic consumables like fusers and transfer belts outweigh the value of the machine. Companies should know what they're selling from a service standpoint as well as $ales.
        • tsbservice
          Field tech
          • 8064
          +1 especially on HP. What a bunch of retards would produce and sell those products! I mean sales not service.
          • JR2ALTA
            • Feb 2010
            • 2033
            I push Kyocera printers for BW, at least. Any machine that has a Maintenance Kit is going to be very serviceable.
