Designjet Z6200 light prints
  • MoochPage
    • Jul 2019
    • 58
    I have a Designjet Z6200 that is printing light or washed out. I printed the same document from a computer through HP click on Z5400 and a Z6200 and the Z5400 looks way closer to the image then the Z6200. While I know they wont be exact but they aren't even close. I have attached them I only got the blue side of the document because of customer info on the rest but I can post more of it later after I alter some things. The background of the whole map is lighter they the one on the Z5400.
    The machine has new printheads and I have run color calibration the diagnostic image looks fine. The color settings on the machines are default I checked to make sure it isn't on ink save mode.
    I am just looking for imputer before suggesting a replacement of the Spectro or main board, carriage or other items without much confidence.
    Re: Designjet Z6200 light prints
    What program are you printing from?
    What are the driver setting?
    Draft mode won't be as sharp or filled in as quality mode.
    • MoochPage
      • Jul 2019
      • 58
      Document is a PDF printed through the HP Click software with identical setting on both machines. I also change it to best mode on the HP Click software in the Z6200 with no noticable change. The Click software doesn't require a driver so no driver was used to eliminate that as a problem.
      • Lance15
        • Jun 2015
        • 1088
        Just worked on a Z6100. Had a similar issue with the magenta/yellow printheads. The yellow looked orange instead of yellow.
        Printheads 7 & 8 should be black/cyan. Yours looks like black/orange.
        Maybe something wrong with the tubes?
        • D Hook
          • Mar 2018
          • 205
          Safe to say you're using the same paper?
          I have all the electronics boards from a Z6200, if you want to try used parts. Cheap. Printer got parted out since ink system was too expensive to fix.
          • Kiran Otter
            • Dec 2013
            • 1114
            Force a printhead alignment on the Z6200. Color shifts and all kinds of weirdness can be due to the alignment. Make sure you're doing it on plain bond white media.
            Kiran
            PS - I wouldn't change any parts before you rule out all the consumables.
              Kiran
              +1
              • MoochPage
                • Jul 2019
                • 58
                Sorry for the delay on update. I am going up tomorrow to update firmware. I will also run alignment and double check internal demo prints.
                Also exact same paper on both machines.
                Thanks for all the imput on ideas one of the more odd ones I have run into on the wide format machines.
