HP Pagewide XL 5200 Firmware
  • jwrycza
    Office Systems Expert
    • Sep 2013
    • 88
    I have downloaded all 4 files from HP website, loaded them on a stick and extracted the zip file there but, it will not load. What is the actual procedure????
  • NS11
    • Dec 2024
    • 2
    Here's the instructions for another HP wide format (Latex 700) in an attachment; I think all the wide format models follow a similar procedure if they require a multi-file firmware download.
    I think this document came from a coworker who got it from HP somewhere/somehow. HP sure doesn't make it simple! On my company laptop that is running Windows 11, I have to use 7-Zip to do this.
      • 22997
      If I remember correctly there's a separate utility to combine the four files into a single firmware file. It's in the same location as you found the firmware.
      • Lance15
        • Jun 2015
        • 1084
        Reading that PDF, it's just a spanned ZIP file. Easily "put back together" as long as you download all of the parts and use 7-Zip or WinRAR. It's pretty much the same as doing:
        copy /b file1.txt + file2.txt + file3.txt file4.txt
