HP DesignJet T1200
  • luis1984bol
    • Nov 2011
    • 155
    [Misc] HP DesignJet T1200
    Hello:
    Does anybody could please help me with this problem?
    As you can see in the images thumbnail_IMG_5694.jpgthumbnail_IMG_5693.jpgthumbnail_IMG_5692.jpgthumbnail_IMG_5691.jpgthumbnail_IMG_5690.jpgthumbnail_IMG_5695.jpgthumbnail_IMG_5699.jpg
    there is a gap in the printed lines.
    The plotter is HP DesignJet T1200. I performed the printhead alignment but the result is canceled by the printer.
    Thanks for your help.
    • 23009
    Re: HP DesignJet T1200
    I think I'd examine, and possibly clean the encoder strip. Ink on the encoder strip can cause this effect. A sticky carriage rail can also cause this effect.
    The encoder strip is a silk-screened strip of mylar that's read by a photointerrupter on the carriage. The machine uses the encoder strip to determine the relative position of the the carriage. =^..^=
    • Kiran Otter
      • Dec 2013
      • 1115
      Blackcat is right. Encoder strip is dirty or the belt needs to be replaced. If neither of those, you have a bad encoder strip and/or encoder sensor.
      Clean the encoder strip with a damp paper towel. Do not use any kind of solvent or alcohol. Pinch the strip between your fingers and the wet paper towel and run along its length gently.
      Kiran
      • D Hook
        • Mar 2018
        • 205
        GENTLY is the keyword. Rub too hard and you'll wipe the marks off the encoder strip, then you'll have to replace it for sure.
