HP P3015 Paper Creasing
  • Rich123
    • Jul 2015
    • 35
    Paper creasing after removing and cleaning registration rollers. Printer was having problem with folding top right edge of paper. I cleaned paper path and feed rollers. Also removed registration rollers and cleaned. After putting back together the machine is no longer folding top right edge, but now is creasing paper like a bad fuser roller. Was not creasing paper at start. Any ideas what happened? Thanks.
    • 23009
    Re: HP P3015 Paper Creasing
    I would suspect that there is uneven pressure at the registration rollers. Maybe a broken bushing, or dislodged pressure spring?
    • Wild Bill
      • Jul 2005
      • 774
      Just to add, possibly build up of toner on fuser guide
      Izzy
      • Rich123
        • Jul 2015
        • 35
        Thanks for your reply. I think I have fixed the problem. I replaced the upper fuser roller about a year ago. I disassemble the fuser and regreased the roller. This seemed to have fixed problem. What confused me is the customer never complained about creasing. It seemed to have started after I cleaned out the paper path and feed rollers. Go figure. Thanks again.
