HP DJ 500 Toner cartridge HP 10 vs HP 82
  • Ben Around
    • Apr 2012
    • 151
    Will the HP 82 toner cartridge work in a HP DJ 500/800? My supplier says they are a replacement for the discontinued HP10 toner cartridge, however the machine will not recognize
    the cartridge. The machine gives an incorrect toner cartridge message.
  • Massimo Italy
    • Feb 2021
    • 45
    Re: HP DJ 500 Toner cartridge HP 10 vs HP 82
    This series use the 82 for color and 10 for black
    • daprex
      • Sep 2009
      • 54
      Also there was a firmware update a few years ago that added something for the consumables, cant remeber if it was the printheads or inks
      • D Hook
        • Mar 2018
        • 205
        Printheads.
        • Ben Around
          • Apr 2012
          • 151
          Originally posted by D Hook
          Printheads.
          Firmware update was to correct a problem with the black print head being rejected
          • Ben Around
            • Apr 2012
            • 151
            Yes that is correct, but the black hp10 was discontinued last November. Some suppliers are selling a black HP 82 cartridge as a replacement for the HP 10.
            I wanted to know if anyone has seen the black HP 82 work in a DJ 500. I think swapping the chip might work.
            • Kiran Otter
              • Dec 2013
              • 1107
              The 82 black ink (not toner) is only for use in the HP DesignJet 111, 510, 510ps.
              Kiran
