HP M607 jam in rear door
  • stobby2
    • Oct 2013
    • 137
    [Jamming] HP M607 jam in rear door
    Anyone had this issue with the HP Laserjet M607 Printer.
    Error code is 13.FF.FF. Unfortunately Customer does not remember the original code when it first jammed.
    Definitely no paper anywhere, checked sensors manually and no apparent problem. Unable to fully test sensors as cannot get into service mode (unless someone knows how with a jam issue). Repaired hundreds of these models but stuck with this one. Fuser in good nick and new toner installed around one month ago according to Customer. Any help or suggestions appreciated. Sorry meant to say. Display states paper jam in rear door with the 13.FF.FF error
  • Lance15
    • Jun 2015
    • 1088
    Re: HP M607 jam in rear door
    Open the rear of the printer like you are replacing the pick and seperation rollers.
    You will probably see the pick roller latch hanging down. I've seen this many times.
