HP Laserjet II / Apple Laserwriter II Redux
  • joeventura
    • Nov 2022
    • 11
    What am I doing on New Years eve? Trying to resurrect this Laserwriter II
    I have replaced the fuser, the 120 V power supply, and the laser scanner.
    This is what a test page is looking like.
    UGH!
    Any ideas?!?!
  • Lance15
    • Jun 2015
    • 1087
    Re: HP Laserjet II / Apple Laserwriter II Redux
    Looks like a bad toner cartridge. Do you have another one to try?
    • subaro
      • Oct 2010
      • 1274
      Agree with the reply. That is most likely the toner cartridge, especially if it is non-oem, plus that new cartridge probably has been sitting in some shelf for a long time, and the shelf life expired. Take back that drum/toner unit and get a replacement.
      Stop the print as the paper reaches before the fuser and remove the drum unit and look at the drum. If you see the smudging on the drum, then replace the cartridge. Those machine the 11 and 111 were solid workhorses in its day and known as Tanks.
      • joeventura
        • Nov 2022
        • 11
        Got out a NOS cartridge and it has greatly improved!!
        Tossed the other one.
        Do the remaining smudges look like still toner cartridge issues?
        And as always THANK YOU!
        • Lance15
          • Jun 2015
          • 1087
          Yes. Still looks like bad toner cartridge.
          I KNOW any NOS cartridge is going to be faulty. Probably better off trying an aftermarket (bite my tongue!).
          • subaro
            • Oct 2010
            • 1274
            Want to resurrect the dead ?. This is where that dinosaur belong.
            HP Computer Museum
            For sure , you would not get an OEM cartridge for that machine, and as I said before those that you do get, most likely is sitting on someone shelf for long time. Nobody runs those machine anymore, way to old. You can shine it up an put it on a display, cause the biggest problem you may have with those is getting reliable toner/drum cartridge.
            • subaro
              • Oct 2010
              • 1274
              You know what. My memory jogged a bit here and I remember the power supply use to have cold solder on the board that use to cause issues [I think it would not turn on was the issue ]. Can't remember what specifically, but it could be related to image quality issue. remove the power supply and inspect it closely . Can't remember if it had a separate HV PS, but you can check it anyway.
                Ditto
                  Ditto
                  def a toner issue
                  • joeventura
                    • Nov 2022
                    • 11
                    Thanks to everyone who replied,
                    I have a "new" cart on order, I am assured its be recently refurbed with a new wiper blade
                    <fingers crossed>
