T520 error 59.2:19 with used Main PCA
  • i-have-fax-problems
    • Mar 2020
    • 108
    I have a T520 which can't be switched on. MainPCA (Main Board) is broken.
    With a used one, I can switch it on but then error 59.2.19 occurs (because of the used board)
    I've resetted the main board (NVRam Reset) but same error.
    Does anyone know any trick, so you can use a used board in this device.
    • 23010
    Re: T520 error 59.2:19 with used Main PCA
    If Hytec repairs these boards, I think I would send it into Hytec to get the PWB initialized, so it's ready for the installation procedure. That's the only suggestion that I have. =^..^=
    • wav
      • Oct 2021
      • 285
      i have a t520 usb drive image see if that will allow it to boot with the other board.
      • BULLDOGG
        • Dec 2023
        • 2
        I bought a used board. Suppose to be for a T520 but shows up as a T120 in PC devices. Would your image fix my issue?
        • wav
          • Oct 2021
          • 285
          It may work.
          If you pm me your email or something I'll send it over
          • wav
            • Oct 2021
            • 285
            Also I do see that you have not a contributed to the forum.
            • BULLDOGG
              • Dec 2023
              • 2
              I'm a contributor now.
