Hp colour laserjet mfp m477fdw black background
  • Latruns
    • Jun 2021
    • 18
    [CQ] Hp colour laserjet mfp m477fdw black background
    Hi felas i hace this issue on colour hp mfp m477fdw when i make copy the black have black background and i change the cartridge even worst than initial one. Pls hope someone can put me through. Thanks in advance
  • GIUBOSS
    • 1385
    Re: Hp colour laserjet mfp m477fdw black background
    Can you give us more information... in print with the pc is it ok? OEM cartridges ? Firmware update?
      If it's totally black I would be looking at the transfer belt, while you are there look for repeating marks about 5 cm apart in the feed direction, this indicates the fuser is faulty. This machine can be expensive to repair.
      • Latruns
        • Jun 2021
        • 18
        Appreciate all your concerns printing from pc make the same copy with photocopy and self test, apart from the background the colour separation look fine.with another cartridge the background still there even more darker. Thanks
        • GIUBOSS
          • 1385
          Original cartridges??? Verify that the side contacts on the toner compartments are not bent or out of position
          • DPS Tech
            • Dec 2023
            • 16
            try a genuine HP black cartridge. The 477's don't always do well with compatibles.
