P3015 tries to select tray 1
  • mascan42
    • 484
    I am getting a prompt to load paper in tray 1 or select a different tray with every print job, even when printing reports from the control panel.
    The trays are all set to letter size plain paper. If I select the specific tray in the print driver, it pulls from that tray. But if I use auto select or printer auto select, it always goes to tray 1 and asks to load paper. And as I said, this also happens from internal prints like reports.
    Is there some setting to set the priority tray? What am I missing?
  • gregrcs
    • 22
    Re: P3015 tries to select tray 1
    Hello,
    Are you using the KX driver ? The XPS driver will give you these types of issues.
    gregrcs
    • wav
      • Oct 2021
      • 285
      if you go to the control panel on a windows pc and then to hardware and sound - -> devices and printers
      --> and you should see your Hp LaserJet p3015 in the list, now right click on the icon and go to printer properties
      then the top tabs you should see device settings in there it should list all the trays and there sizes
      if you not planning to use the tray 1 / mp tray then change it to some other size like c5 envelope.
      and then make sure your other trays or tray has the correct paper size and then press apply
      See if this helps.
      • gregrcs
        • 22
        My bad. Thought you were speaking of the kyocera p3015.
        • mascan42
          • 484
          Originally posted by wav
          See if this helps.
          Unfortunately, the customer does use tray 1 for printing labels occasionally, so this isn't an option. Also, the problem isn't in the driver, since it happens when printing internal reports from the control panel as well.
          • wav
            • Oct 2021
            • 285
            Have you tried a firmware update.
            • mascan42
              • 484
              Might be tricky with the security in this place. No laptops or unauthorized downloads allowed.
              • wav
                • Oct 2021
                • 285
                I see.
                Could you make a request to see if it can be checked.
                Sent from my SM-G998B using Tapatalk
                • Lance15
                  • Jun 2015
                  • 1089
                  Go into the Printing Menu and check the MANUAL FEED option. Is it turned ON or OFF (default)?
                  If it's turned on, the printer will ALWAYS try feeding from the manual feed tray first.
                  • DPS Tech
                    • Dec 2023
                    • 16
                    Go to your paper handling and see what it says you have in tray 2. If it thinks you have a different size or type, then it is going to ask for the size or type to be loaded in tray 1. What does the config page say for size and type in tray 2?
                    • DPS Tech
                      • Dec 2023
                      • 16
                      You could try a cold reset. That has fixed alot of strange glitches for me over the years.
                      • DPS Tech
                        • Dec 2023
                        • 16
                        try a cold reset. That has fixed a lot of strange glitches for me over the years.
